SAS drives have different type of connector, which have data and power combined. Regular SATA connectors will not work on SAS drives.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/1185315-sas-power/#findComment-13534775
On 4/28/2020 at 8:16 AM, wheels90 said:
Because I have a SAS controller
Hi, it might be too late now, but you might want something like this:
(Newegg search for "CableDeconn Internal Mini SAS 36pin SFF-8087 to (4) 29pin+15Pin SFF-8482 connectors with SATA Power 0.5M " as an example in case link blocked)
One end has a SFF-8087 to connect to a controller (but there are other connectors, so make sure it's compatible) and the other end splits into 4 SFF-8482 connectors, each for one sas drive, with a slot on the back for a standard SATA power plug.
Link in the next post, in case it helps?
https://linustechtips.com/topic/1185315-sas-power/#findComment-13550938
link:
https://www.newegg.com/black-cabledeconn-0-5m-cable-connectors/p/238-009E-00026?Description=sata to sas adapter&cm_re=sata_to_sas_adapter-_-238-009E-00026-_-Product
https://linustechtips.com/topic/1185315-sas-power/#findComment-13550940
