I need desperate help im panucking like shit. So im new to pc i just got my first pc and it has bad frames on games even with worse settings. It seems like my xbox is better which shouldnt be tge case as if i use 1080p settings in my games it will get like 20 frames and lag whereas on xbox it is fine. Please help.
https://linustechtips.com/topic/1185239-help/
You need to list your computer specs and what you're playing
If possible, download HWiNFO and check the sensor data for temperatures while in game
https://linustechtips.com/topic/1185239-help/#findComment-13534162
You don't exactly have a gaming system... Try lowering the resolution and turning settings down.
https://linustechtips.com/topic/1185239-help/#findComment-13534217
9 minutes ago, Cc1804 said:
Wait so your telling me that my 300pound xbox is better than my 550 pc
3000G isn't a cpu great for any intensive tasks at all really. You kind of wasted your money on this pre built system.
Build this system, if that's your budget. Make sure you quote when you respond.
https://linustechtips.com/topic/1185239-help/#findComment-13534256
