skimped way too much on the PSU and CPU, while you went all out on case and motherboard.
Change it to something more like this:
You still get a nice NZXT case, and you gain a much faster CPU. I also upgraded the GPU but you could keep the 590 for your budget. The PSU is much better, and the motherboard is still plenty decent for a nice upgrade path.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1185208-first-computer-build/#findComment-13534053
2 minutes ago, Toska513 said:
I think I'm gonna keep the power supply cause my build will only take a little over 400 watts at
Max and i don't really plan on over clocking but yeah ur prob right about the CPU.
I don't think skimping the CPU is a good idea regardless of the power draw.
Main Rig :
Ryzen 7 2700X | Powercolor Red Devil RX 580 8 GB | Gigabyte AB350M Gaming 3 | 16 GB TeamGroup Elite 2400MHz | Samsung 750 EVO 240 GB | HGST 7200 RPM 1 TB | Seasonic M12II EVO | CoolerMaster Q300L | Dell U2518D | Dell P2217H |
Laptop :
Thinkpad X230 | i5 3320M | 8 GB DDR3 | V-Gen 128 GB SSD |
https://linustechtips.com/topic/1185208-first-computer-build/#findComment-13535977
12 minutes ago, Toska513 said:
Yeah I know thats why I said he right about the CPU part which i took his recommendation and changed it to what he suggested
Sorry I meant PSU.
Main Rig :
Laptop :
https://linustechtips.com/topic/1185208-first-computer-build/#findComment-13536035
  Hide contents
I agree but with his build the stock fans on the nzxt are all that is needed.  The case is $10 cheaper at nzxt.com with free shipping.
https://linustechtips.com/topic/1185208-first-computer-build/#findComment-13538382
The H510 only comes with a single intake fan, and a single exhaust fan. A second intake fan will improve thermals, which will improve graphics card clock speeds so more performance. Worth the small extra spending.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1185208-first-computer-build/#findComment-13538398
Actually it comes with two exhaust and no intake installed.
With his build he should start with the stock and then add more if he wants.
Since he switched to a 3600, he will probably need to improve the cooling on that first.
With first-time builds it’s best to start with stock cooling and then improve if one wants.  It’s something one can easily and cheaply improve later on.
https://linustechtips.com/topic/1185208-first-computer-build/#findComment-13538459
