So i was trying to customize my LEDs configurations through QMK and what i was trying to do is make all my LEDs glow cyan and making my arrow keys turn red when caps-lock is active.
I can't seem to understand how to do anything at all so I was hoping on your help.
Here's what my configuration looks like atm (basically default but have right gui and MO(1) switched)
#include QMK_KEYBOARD_H
enum ctrl_keycodes {
    U_T_AUTO = SAFE_RANGE, //USB Extra Port Toggle Auto Detect / Always Active
    U_T_AGCR,              //USB Toggle Automatic GCR control
    DBG_TOG,               //DEBUG Toggle On / Off
    DBG_MTRX,              //DEBUG Toggle Matrix Prints
    DBG_KBD,               //DEBUG Toggle Keyboard Prints
    DBG_MOU,               //DEBUG Toggle Mouse Prints
    MD_BOOT,               //Restart into bootloader after hold timeout
keymap_config_t keymap_config;
const uint16_t PROGMEM keymaps[][MATRIX_ROWS][MATRIX_COLS] = {
    [0] = LAYOUT(
        KC_ESC,  KC_F1,   KC_F2,   KC_F3,   KC_F4,   KC_F5,   KC_F6,   KC_F7,   KC_F8,   KC_F9,   KC_F10,  KC_F11,  KC_F12,             KC_PSCR, KC_SLCK, KC_PAUS, \
        KC_GRV,  KC_1,    KC_2,    KC_3,    KC_4,    KC_5,    KC_6,    KC_7,    KC_8,    KC_9,    KC_0,    KC_MINS, KC_EQL,  KC_BSPC,   KC_INS,  KC_HOME, KC_PGUP, \
        KC_TAB,  KC_Q,    KC_W,    KC_E,    KC_R,    KC_T,    KC_Y,    KC_U,    KC_I,    KC_O,    KC_P,    KC_LBRC, KC_RBRC, KC_BSLS,   KC_DEL,  KC_END,  KC_PGDN, \
        KC_CAPS, KC_A,    KC_S,    KC_D,    KC_F,    KC_G,    KC_H,    KC_J,    KC_K,    KC_L,    KC_SCLN, KC_QUOT, KC_ENT, \
        KC_LSFT, KC_Z,    KC_X,    KC_C,    KC_V,    KC_B,    KC_N,    KC_M,    KC_COMM, KC_DOT,  KC_SLSH, KC_RSFT,                              KC_UP, \
        KC_LCTL, KC_LGUI, KC_LALT,                   KC_SPC,                             KC_RALT, KC_RGUI, MO(1), KC_RCTL,            KC_LEFT, KC_DOWN, KC_RGHT \
    [1] = LAYOUT(
        _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______,            KC_MUTE, _______, _______, \
        _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______,   KC_MPLY, KC_MSTP, KC_VOLU, \
        _______, RGB_SPD, RGB_VAI, RGB_SPI, RGB_HUI, RGB_SAI, _______, U_T_AUTO,U_T_AGCR,_______, _______, _______, _______, _______,   KC_MPRV, KC_MNXT, KC_VOLD, \
        _______, RGB_RMOD,RGB_VAD, RGB_MOD, RGB_HUD, RGB_SAD, _______, _______, _______, _______, _______, _______, _______, \
        _______, RGB_TOG, _______, _______, _______, MD_BOOT, NK_TOGG, _______, _______, _______, _______, _______,                              _______, \
        _______, _______, _______,                   _______,                            _______, _______, _______, _______,            _______, _______, _______ \
    [X] = LAYOUT(
        _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______,            _______, _______, _______, \
        _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______,   _______, _______, _______, \
        _______, _______, _______, _______, _______, _______, NK_TOGG, _______, _______, _______, _______, _______,                              _______, \
// Runs just one time when the keyboard initializes.
void matrix_init_user(void) {
// Runs constantly in the background, in a loop.
void matrix_scan_user(void) {
#define MODS_SHIFT  (get_mods() & MOD_MASK_SHIFT)
#define MODS_CTRL   (get_mods() & MOD_MASK_CTRL)
#define MODS_ALT    (get_mods() & MOD_MASK_ALT)
bool process_record_user(uint16_t keycode, keyrecord_t *record) {
    static uint32_t key_timer;
    switch (keycode) {
        case U_T_AUTO:
            if (record->event.pressed && MODS_SHIFT && MODS_CTRL) {
                TOGGLE_FLAG_AND_PRINT(usb_extra_manual, "USB extra port manual mode");
            return false;
        case U_T_AGCR:
                TOGGLE_FLAG_AND_PRINT(usb_gcr_auto, "USB GCR auto mode");
            return false;
        case DBG_TOG:
            if (record->event.pressed) {
                TOGGLE_FLAG_AND_PRINT(debug_enable, "Debug mode");
            return false;
        case DBG_MTRX:
                TOGGLE_FLAG_AND_PRINT(debug_matrix, "Debug matrix");
            return false;
        case DBG_KBD:
                TOGGLE_FLAG_AND_PRINT(debug_keyboard, "Debug keyboard");
            return false;
        case DBG_MOU:
                TOGGLE_FLAG_AND_PRINT(debug_mouse, "Debug mouse");
            return false;
        case MD_BOOT:
                key_timer = timer_read32();
            } else {
                if (timer_elapsed32(key_timer) >= 500) {
                    reset_keyboard();
            return false;
        case RGB_TOG:
              switch (rgb_matrix_get_flags()) {
                case LED_FLAG_ALL: {
                    rgb_matrix_set_flags(LED_FLAG_KEYLIGHT | LED_FLAG_MODIFIER);
                    rgb_matrix_set_color_all(0, 0, 0);
                  break;
                case LED_FLAG_KEYLIGHT | LED_FLAG_MODIFIER: {
                    rgb_matrix_set_flags(LED_FLAG_UNDERGLOW);
                  break;
                case LED_FLAG_UNDERGLOW: {
                    rgb_matrix_set_flags(LED_FLAG_NONE);
                    rgb_matrix_disable_noeeprom();
                  break;
                default: {
                    rgb_matrix_set_flags(LED_FLAG_ALL);
                    rgb_matrix_enable_noeeprom();
                  break;
            return false;
        default:
            return true; //Process all other keycodes normally
Thank you in advance for every bit of help that you will give
https://linustechtips.com/topic/1184528-drop-ctrl-leds-configuration-need-help/
