3 minutes ago, Cargamer1346YT said:
So I was Installing Windows 10 And When I Got To Choose The Hard Disk To Install It In I Got This Error
It looks like you might have bad installation media. Assuming this is Windows 10, recreate your bootable media with the tool from https://go.microsoft.com/fwlink/?LinkId=691209.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/1184478-help/#findComment-13528549
You need to create a new partition, currently it is unallocated. You can also merge them together to get a single ~8TB parition.
-Moved to Troubleshooting-
https://linustechtips.com/topic/1184478-help/#findComment-13528556
