RGB Fusion stopped working?! (HELP)
Solved by Emrakul,
Hi Kranolf, unfortunately from what ive been able to find out after experiencing this issue is that gigabyte uses outdated drivers, or drivers that are generally exploitable to hackers, so valorant's anti cheat stops it from running or functiong, im not sure why they disbale it when you arent playing valorant, but if you uninstall all of valorants programs and valorant itself, you will be able to use rgb fusion again, so I guess right now its either rgb fusion or valorant
