Hello All,
First time doing a custom loop, and have a 2080 and 9700k running on it, not doing any overclocking. Fans running pretty high as well, yet under load CPU can reach mid 80s, even though the GPU may only be at like 40. Cpu also sometimes just doesn't stay under load, and can fluctuate heavily at times while in game. Lastly, CPU temps also rise and fall very quickly with load%, so the instant the load goes from say 5 to 80%, the temp will quickly jump from its idle of 35 up to around 70. This seems highly odd to me, am I just being weird, or is something probably wrong. Using a H700 case, strix Z390 mobo, 8GB ram (working on getting 16), RTX 2080 (the MSI EKWB one), and a 9700k with a 240mm slim and 280mm slim rad to cool it.
Any ideas?
https://linustechtips.com/topic/1184196-odd-cpu-usage-and-temps/
1 minute ago, Paulelele said:
Any ideas?
What tasks are you doing?
How is your air flow?
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
Literally jsut playing games like Cod Warzone, with just CAM and Discord open, airflow should be fine, 6 total fans, all running high rpm, case does choke rads a little however
25 minutes ago, _DeXTeR_ said:
Dont you think that is maybe to high to run 100fan RPM on 40c only ? Well I was using 25 RPM under 40c 50% 60c and everything above 60c goes same with RPM.  Try to have fan speed higher from Pump.
Fan speeds go to around about 1000 rpm, cant put them any higher
