Motherboard: Asus P5K
CPU: Intel quad core q6600
GPU: 7100 GS
PCU: MS Pro-550ATX P4
This is a very old PC and i know that
I want to buy a new GPU and i wanted the RX580 8GB but my PCU has only a 6 pin connector
I know my system is too old for that GPU but i wanted to buy a GPU now and put it in my pc and buy all of the other parts in about 6-7 weeks
Can u help me solve my 6 to 8 pin problem
Should i just buy a new PSU with the RX580 right now or what?
Thank u...
https://linustechtips.com/topic/1184015-psu-problem/
GPU: 7100 GS
Thank u...
What PSU are you currently running in the system, not that pre-builds may have proprietary motherboard connectors that may or may not work with a standard off the shelf PSU?
I would upgrade the CPU to a Q9650 and add in more RAM and an SSD if needed.
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/1184015-psu-problem/#findComment-13525622
2 hours ago, MrTodoroski said:
MS Pro-550ATX P4
Not only is that a very old PSU... it's a very BAD PSU.
Not only does it only have one 6-pin PCIe connector, it only has 192W available on the +12V and works only at 230V mains (which means if the mains drops, the PC shuts off or the PSU blows up).
https://linustechtips.com/topic/1184015-psu-problem/#findComment-13525933
