multi boot usb stick
By
legopc
in Peripherals
in Peripherals
Solved by rustikles,
the wiping is no problem it just writes over the files of the win install
If you have the Windows installation as an ISO, Yumi shouldn't edit it at all, just write files to mark it as an installation. You are scrolling down to the bottom of that distro list it gives you and choosing unlisted (Grub) right? Once it finishes, there should be a popup asking if you want to add more ISOs.
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases4 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18 -
1
play_circle_filled
Latest From ShortCircuit:
