Not enough fan placement
Go to solution Solved by itisme911,
No, You have enough cooling anyway, Just make sure intake etc is optimized, Having your cooler vent up helps a bit but not necessary, With your current setup just try to have meybe top and front intake for positive airflow out the rear of the case.
Right now my front have 2 intake, my back 1 exhaust and my top is 1 exhaust as well is it allright ?
1 minute ago, itisme911 said:
A lot of people like that and is fine but the probably negative air pressure pulls in dust from holes in case and rear. The top and front usually have dust filters or stay cleaner so work as cleaner intake.
Allright thanks a lot for your help!
