Hi! I'm a newbie to streaming and looking for some help.
I'm Currently running a gaming rig (specs below) and am streaming directly off it on to OBS and then to twitch. Needless to say, the gaming performance is being cut down and my stream is looking like crap.
I'm considering buying an Elgato 4k card and strapping it in my old rig but I am unsure if it will be able to handle the load as I never used it for streaming.
I currently play 95% games at 1440p 144hz and am going to stream at 1080p 60fps. I also plan on linking a Sony a6000 as a webcam.
Any help or insight would be appreciated!
Gaming Rig:
CPU: Ryzen 5 2600x
GPU: AMD RX 5700XT 8GB
RAM: 16gb 2400mhz
Streaming Rig:
CPU: AMD FX 8320
GPU: GTX 1060 3GB
RAM: 8gb 1600 mhz
Capture card: Elgato 4k60 (proposed)
https://linustechtips.com/topic/1183573-help-with-streaming-rig/
