Build Help: Looking for help on my build since my knowledge on computer building is very limited. The PC will be mainly used for gaming, streaming, watching shows. I'm currently playing League of Legends, Final Fantasy XIV but want to be able to play new AAA games at High settings close to 144 FPS at 1080p but its not required around 120 is fine. I also stream on twitch once in a while and use dual monitors if that matters. My budget is $1200. I'm set on the NZXT H510 case because of the aesthetics and don't want to change it out unless its really going to hinder airflow or the pars don't fit. I have access to microcenter so the Ryzen 7 3700x is at $269.99. I can bundle it  with the Gigabyte x570 Aorus Ultra to save an additional $20 but I don't know if its worth it for the added cost of the Aorus Ultra. For RAM is it ok to go for just DDR4-3200 or should i just get the DDR4-3600? It seems worth it just for an $8 difference. Also would I be able to get by with just my old GTX 970 til the new cards come out? I'm ok with playing at lower frame rates and settings as long as the game can run still decently well.
https://linustechtips.com/topic/1182743-final-build-check/
any 550w psu will do. like corsair cx/txm/rm. antec neo eco gold 550/650w
bad airflow case. get fractal desing focus g instead.
asus prime-P is better x570 board.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1182743-final-build-check/#findComment-13516913
I'm going to get the asus P Prime like you recommeded. They also have it for a bundled on microcenter
https://linustechtips.com/topic/1182743-final-build-check/#findComment-13517154
