Help My WIFI
Solved by WereCatf,
5 minutes ago, Prius Is Suck said:do you guys know how to search Phone Info From Ip Address?
You can't do it like that. The IP-addresses are given by your router, they have nothing to do with what model a phone is or anything like that.
You should change your WiFi-password and disable WPS. Also make sure you are using WPA2-AES as the security-model for your WiFi, not WPA or WEP or mixed-mode.
