First Build GPU Questions: HELP!
Go to solution Solved by M4R1S,
Although your cable management isn't perfect, the temps are quite unusual. GPU's should be around 75 to 85 under load. All of the GPU fans are working?
Hello, first and foremost I would like to state that my computer building and knowledge of PCs is rather low so please understand that this may be a rather "noob" question.
I have recently built a entry level budget gaming/work PC with the following specs:
CPU: Ryzen 3 2200G
MOBO: B450M/ac
RAM: 8gb (2x4gb 2666 MHz)
GPU: Radeon RX 580
I just installed the GPU and was using the APU until this last week, so I was monitoring the specs of the RX 580 with HW Monitor. The case I am using is a Rosewill Ranger M with little to no cable management room so my insides are a hot mess (quite literally) as my GPU was clocking in at  85-90 degrees Celsius while playing.
Long story short, my questions are as follows for anyone that may be able to offer guidance:
-What is considered a safe range for GPU temps? I was only playing for about 20-30 minutes by the time it reached 90
-Does cable management effect my temp issues all that much in this case? Photo of my build for reference.
-Would anyone recommend an open concept style case or a test bench case option instead? I am rather fond of the look of the test bench instead of a case but worry if that may not be safe or practical for a day to day use computer like mine.
Thank you in advance!
IMG_5191.HEIC
https://linustechtips.com/topic/1181809-first-build-gpu-questions-help/
Sorry I cannot view the photo, please just paste it in the post.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
That is hot.
System specs below
PSU: Corsair CX650M
3 minutes ago, MyNameIsWyatt said:
Sorry, here is a google photo link.
Fix the cables and see what happens.
System specs below
PSU: Corsair CX650M
