Doing my first build--got everything in place correctly, all the correct wires, ports ect. Plugged in my PSU power cable, flipped the switch to "on" and only the Mobo's rgb came on. No fans, no lights--nothing. I did the paperclip test and the PSU runs fine. Brand new CPU with no bent pins, and RAM sticks. A week ago, my dumbass took the motherboard out on carpet to look at the headers  so i assume that might have shocked it? I ordered a replacement Mobo and swapping it out did nothing. Does anyone have any troubleshooting?
  • AMD Ryzen 5 3600 3.6 GHz 6-Core Processor
  • Asus ROG STRIX B450-F GAMING ATX AM4 Motherboard
  • Crucial MX500 500 GB 2.5" Solid State Drive
  • Gigabyte GeForce GTX 1660 6 GB OC Video Card
  • Thermaltake Smart 700 W 80+ Certified ATX Power Supply
  • Phanteks ECLIPSE P350X ATX Mid Tower Case
https://linustechtips.com/topic/1181595-help-pc-wont-boot/
Check one by one. No Fans, no GPU, only one RAM ect. See if it boots that way. If it does, add the rest one by one.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1181595-help-pc-wont-boot/#findComment-13508662
On 4/21/2020 at 10:47 AM, boggy77 said:
ram in slots 2 and 4?
Found out my motherboard needed a bios update with an older processor and even with the older one, it wouldnt boot.
And yes about the ram. Even changed my mobo to an ASUS X570-P and I'm still having the same issues. I'm thinking its my PSU...
https://linustechtips.com/topic/1181595-help-pc-wont-boot/#findComment-13518698
3 hours ago, DDrew95 said:
Same thing. Only the MOBO light came on. With both processors straight out the box.
Since you replaced the MB, i doubt thats your Problem.
Are you sure you did all the cablemanagement right?
Its your first build after all.
https://linustechtips.com/topic/1181595-help-pc-wont-boot/#findComment-13519348
