problems with intel ax200
Solved by Alex Atkin UK,
6 hours ago, I.C.Y said:i dont see it... isn't that thing soldered on the mobo?
I do not believe the AX200 comes in a soldered version, its specifically M.2 2230 or M.2 1216.
I think most motherboards bury it behind a shield around the antenna sockets and even worse some seem to hide it under the VRM heatsink.
That said, if its faulty is the motherboard under warranty? I'd also be tempted to wonder if its the router or Windows. I've personally found the AX200 pretty good.
