CPU Help (EDC at 99%)
Solved by SavageNeo,
3 minutes ago, GrimReapez said:It seemed to lower itself to 64% . But what exactly happen. and what issues could have it been causing?
the EDC; PPT and TDC are power limits. That meant that your cpu was maxing out the EDC power limit. in precision boost overdrive you can set the limit higher manually. if it exceeds the limit your cpu might not boost to higher frequenzy's.
