If you haven't updated the BIOS in 2 years, you might need to.
Other than that the 2600 will be a nice upgrade, so long as you already have a discrete GPU, since the 2600 does not.😁
F@H    EOC
Folding Rigs
Toaster Oven: RTX 3070 Ti & R5 7700X
Meth-Uselah: RTX 2070S & R5 3600X
Pecan't Pi: Raspberry Pi 5
ZZ Laptop: Asus ROG Zephyrus G15
I sent pictures of my bios above if that helps :)
I would update it to version 7A36v2H just to be safe. Make sure to update your chipset driver as well .
https://www.msi.com/Motherboard/support/A320M-PRO-VD-S#down-driver&Win10 64
F@H    EOC
Folding Rigs
I tried updating earlier but in the M-Flash it didn't show up the files (the picture is the same as what it was like earlier)
5 hours ago, sootngiz said:
image.png.be449cf4ecff1ff8bc9f596fa567097e.png do I just run that exe and it will update my chipset driver? I haven't got my ryzen 5 2600 since its on the way so will i wait until it comes or now?
Sorry for the delay, was running errands.
Yes, run that .exe file and the setup wizard should walk you through
F@H    EOC
Folding Rigs
Your USB flash drive has to be formatted as FAT32.
When you download a BIOS from the MSI website, it's a .zip file. You should extract the .zip file, and move the files to the USB flash drive. Or follow MSI's M-FLASH walkthrough: https://www.youtube.com/watch?v=LRyFMf0D9Lc
Definitely go with the BIOS version listed above by jctappel67. Update chipset drivers. In the end you should have an updated BIOS, new CPU, updated chipset drivers.
My USB is formatted as FAT32, I extracted the zip file and put the files on my USB.
