Speaker problem
Go to solution Solved by ethernetery,
It's fixed
2 minutes ago, Ridska said:
More information please.
And if i understood it correctly The speaker right side starts playing but the left side is silent and vise versa ?
What type of information would you like?
no, the speaker right side plays the left and vice versa
https://linustechtips.com/topic/1179207-speaker-problem/#findComment-13491355
Information like, do you use any sound cards or DAC/AMPS ect, It might be a faulty cable or the jack isnt plugged in all the way in.
(⌐■_■)
https://linustechtips.com/topic/1179207-speaker-problem/#findComment-13491369
6 minutes ago, Etheaary said:
I have no soundcards or amps. I use the integrated motherboard thing. It is plugged in all the way
what cable are you using as an input and output? meaning, Are you using both way male jacks from your speaker to your mobo's green port I/O ?
It might be a faulty cable, Also, what speakers are you using?
(⌐■_■)
https://linustechtips.com/topic/1179207-speaker-problem/#findComment-13491382
  • 2 weeks later...
