not really working with much. 50 euros doesn't get you a quality unit. Plan on putting a GPU with this CPU?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1179014-power-supply/#findComment-13489275
Cooler master elite V3 fits the budget, or the enermax MAXPRO.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1179014-power-supply/#findComment-13489305
well since this is the second thread:
Quote
Group regulated unit, and there are far better offerings on the market
https://www.amazon.it/quiet-System-Power-alimentatore-computer/dp/B079KG3TZ5/ref=mp_s_a_1_9?dchild=1&keywords=system+power+9&qid=1586986249&sr=8-9
If you can chip in the extra, then this is a much better unit.
Edit: or this from germany
https://de.pcpartpicker.com/product/DWKcCJ/xilence-performance-a-530w-80-bronze-certified-atx-power-supply-xn061
here is what i found last time around.
https://linustechtips.com/topic/1179014-power-supply/#findComment-13489364
