Hello. I am wondering if there is any possible way I may get the best possible performance out of my AMD FX-8350 Black Edition. I am figuring that my motherboard(It's An AsusTek M5A97 2.0) is holding me back. It has the option to OC, and i Have, but im feeling like it may or may not be a latency issue.. I have already OC to a constant 4.4Ghz. Temps Are good. I just feel like i could do more with this CPU. My PC Specs are below.
Mainboard: AsusTeK M5A97 2.0
CPU: AMD FX-8350 Black Edition OC'ed to 4.4Ghz
RAM: 8GB DDR3 @2317.MHz
GPU: AMD Sapphire Nitro+ RX 470 Quad-Bios Gaming/Mining Card(Yes they have those....You wanna argue i can post a feking video. test me...)
Storage:
1 SPCC 250GB SDD
1TB WD WD10EZEX-08M2NA0 HDD
OS: Windows 10 Pro N
https://linustechtips.com/topic/1176735-advice/
  • 4 weeks later...
Storage:
1 SPCC 250GB SDD
Yes Id like to test you on the gaming card running a mining bios.
Exactly how many issues have you or plan to encounter??
FX at the right voltage (1.5v) will do around 5ghz.
https://linustechtips.com/topic/1176735-advice/#findComment-13565023
