Soo this is my build so far, My budget is 800ish and it’s my first gaming pc build. is this good?
Do you guys think I need any specific cooler fans or am I good ?
also do you guys think I should get a Crucial P1 500 GB M.2-2280 NVME Solid State Drive or stick with the SSD I got listed
https://linustechtips.com/topic/1176386-help-revise-my-build/
It's a really solid build, personally I wouldn't change a thing. Basically you've selected the cheapest good parts in your respective price brackets.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1176386-help-revise-my-build/#findComment-13469540
If you can spend the extra $20 on an NVME instead of a SATA, I would do so. NVME is faster and it just looks nicer in systems. Also, Ryzen CPUs come with CPU coolers than are more than adequate. Unless you are doing heavy overclocking, I wouldn't spend cash a cooler.
https://linustechtips.com/topic/1176386-help-revise-my-build/#findComment-13469541
build is solid as Fasauceome said. if you can find corsair txm 550w at a good price you should get that unit. corsair cx is decent but txm is generally little better.
or i would get 50dollar 2tb hdd since that ssd can get full really quick
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1176386-help-revise-my-build/#findComment-13469581
if you can link. Me or tell me where they sell that PowerSupply that would be nice because I can’t seem to find it myself.
but Would a Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive make up for that SSD?
https://linustechtips.com/topic/1176386-help-revise-my-build/#findComment-13469807
you mea replace the ssd? the do not.
i meant that go with that ssd and this hdd.
https://linustechtips.com/topic/1176386-help-revise-my-build/#findComment-13469860
Oh no that’s not what I meant but okay I get it. Is the hard drive I mentioned good ? Or is there a better option because I might get a Crucial P1 500 GB M.2-2280 NVME Solid State Drive to replace the SSD I listed in my original post
https://linustechtips.com/topic/1176386-help-revise-my-build/#findComment-13469879
yes the hdd is good.
and yes replace the ssd with that m.2ssd
https://linustechtips.com/topic/1176386-help-revise-my-build/#findComment-13469990
