I am trying to decide my upcoming local ghost s1 build. I plan on using a Ryzen 7 3700x + RTX 2080 Super. I do not know whether the Noctua NH- L12 + Small top hat with 2x slim 120mm Noctua fans would be enough to keep the system under safe temps without hindering the performance or whether a large top hat with a 240 mm I would be at the way to go in order to not hinder the performance of either the CPU or GPU. The only reference material I have found is...
http://louqe.com/img/GhostToHatTest.pdf
(basically either the S or the L+ build options in the pdf)
But their benchmarks use, easier to cool components and I do not know whether the S solution would be adequate.
https://linustechtips.com/topic/1176361-loque-ghost-s1-cooling/
I saw an Optimum Tech video, and if you don't have a bottom mounted drive, you can fit a full 120mm fan as exhaust, and have either 1) a small tophat with 2 fans as exhaust, or a large tophat with aio as exhaust. That way, negative pressure can pull in air from the sides.
This does have a lot of dust buildup though.
"hi 911? my grandma is on the floor and shes not responding to anything"
"have you tried turning it off and on again?"
ding ding ding ding ding ding ding, di-di-ding
https://linustechtips.com/topic/1176361-loque-ghost-s1-cooling/#findComment-13469349
