Loque Ghost S1 cooling
Solved by WoodenMarker,
Yes, it should be fine for keeping temps in check although I'm not sure about the numbers.
I've read of a few people who run a similar configuration that seems to work fine.
https://forum.quartertothree.com/t/amd-ryzen-discussion/128606/548
https://www.reddit.com/r/Louqe/comments/er6iew/ryzen_9_3900x_ghost_s1_cpu_cooler/
A 240mm isn't necessary but would perform better. The 3900x will practically always perform better with better cooling so it's essentially impossible to not hinder it but the gains aren't necessary huge.
