Hey!
4 days ago, I decided to get new ram to replace my old ram. I used to have 2 sticks of 8GB, and I switched them out for another 2 stick of 8Gbs, but the new sticks were faster. After doing so, my pc booted up but won’t access windows. Everything worked perfectly fine, I was able to go into my bios and change setting, but I wasn’t able to get into windows. I tried changing some settings in the bios, I tried resetting my cmos, but nothing seemed to work. I tried using the old ram, but this didn’t work either.
After talking to a friend, I decided to get a new motherboard, but sadly, this doesnt seem to work as well. Currently, my pc boots, reboots twice, and then seems to work perfectly fine, but  it boots without display. The VGA bug light on my motherboards is turned on.
I tried booting my pc up without the gpu, doesnt work. I tried booting my pc up with the old ram, doesn’t work. I tried another psu, doesnt work.
Can someone please help me?
CPU: intel i7 6700k
GPU: Gigabyte gtx1070
Ram: Corsair vengeance LPX 2x8 3200mhz
Motherboard: Gigabyte Z390D
https://linustechtips.com/topic/1176318-booting-without-display/
