Forum help
Solved by Antistatic12,
Over 500 posts.
At 500 posts users can select a custom title. Please remember to keep them appropriate and that also post count farming to get to this stage is against the forums CoC. Note that if your title is "Member" or "Members" but you do not have between 25-99 posts, you have the vBulletin title set.
These titles are not to be confused with the user groups which are displayed below a users avatar - these groups correspond to whether you're a member, moderator, administrator, etc.
