6 minutes ago, Bmh20 said:
Hello all i hope i can get some help with this. I am looking for a case that has some good RBG qualities while also allowing for some great air flow
There are several questions that would help to know:
1.  Country (for pricing)
2. Budget
3. Size of case - do you want Full, Mid Tower (ATX), Micro, etc...
https://linustechtips.com/topic/1176023-choosing-a-case/#findComment-13466753
1 hour ago, Bmh20 said:
U.S., nothing over 150 and Mid Tower
Only cases I can think of without adding your own fans would be Corsair iCUE 465X RGB, Corsair iCUE 220T RGB Airflow and the Phanteks Eclipse P400A Digital (if you can find it in stock for $90-100)
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
https://linustechtips.com/topic/1176023-choosing-a-case/#findComment-13466964
