240hz monitor cable
Geoka
Hello there, I just got an Acer Nitro xf252q and it doesn't come with a display port cable. What cable would you recommend for 240hz.
I have a 2080ti, the monitor came with a good quality hdmi as it says on it which I'm not to sure about it. Also I believe you will ll be able to see the difference using a displayport cable, right? Any recommendations? Link would be nice, thank you
You just want to get a Display Port. You can get a bog standard one for about $8 here.
