Hi,
I'm new to pc building so I wanna know if these configs are good to begin or bad or idk if you have some advice just tell me it'd be very cool !
And yes it's in euros because I'm French sry if it confuses you.
My current config is
  • Intel Xeon E3 1225
  • HP 802F KBC Version 05.22
  • 16 Go of RAM (4x4)
  • NVIDIA GeForce GTX 1050
Edited by Ethan74
https://linustechtips.com/topic/1175818-first-pc-build-ever/
the build above looks fine but does the case come with fans?
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1175818-first-pc-build-ever/#findComment-13465272
4 hours ago, Meganter said:
Thanks a lot for your time it really helps me, 866€ is a lot but I think it’s worth it for a good gaming pc !
https://linustechtips.com/topic/1175818-first-pc-build-ever/#findComment-13465835
17 minutes ago, Ethan74 said:
@Meganter I notice the case (Cooler Master MasterBox MB511 ATX Mid Tower Case) comes with 1 fan of 120mm at the back of the case, do I need 2 other fans to put at the front of the case or I can build my pc with this fan alone ?
Oh yes I forgot to add 2 more fans, my bad. Also you can look at the MB511L, a little more expensive but comes with 1 120mm fan at the rear and 3 120mm RGB fans at the front.
https://linustechtips.com/topic/1175818-first-pc-build-ever/#findComment-13473029
Thank you very much I appreciate your time and your fast replies. You've been useful for the choice of my parts, thanks a lot ! 😉
https://linustechtips.com/topic/1175818-first-pc-build-ever/#findComment-13473039
