Hey, I got a old r9 280x from a friend and he said that it wasn't working.
That it just blackscreened his PC, after installing it in my PC I booted up windows normaly and was able to install drivers with no issues, but the moment I started up a GPU intensive task ( In this case I opened up World of Warcraft) the PC just restarted, no BSOD or anything just a insta shutdown and booted up again.
After testing I've noticed that it can handle lower GPU loads (Ran heaven benchmark with diffrent settings, specificly lowering the resolution made the crashes stop fully, it ran on ultra with 1280x1024 resolution with no issues, then I tried running it at 720p it made it half way and again crashed), I also cleaned the GPU from any dust, the PSU is a 650W unit that is old 2 weeks so it shouldn't be a problem.
Any help would be much appreciated, and if there is a faulty component on the GPU how does one test to see what part is wrong. Thanks in advance and sorry for bad english
My PC:
Intel core I5-2400
XFX R9 280x DD Black Edition (Currently using old Zotac GTX 750 TI 1GB)
Generic 2x2 and 1x4 GB ram
Corsair CV650
128GB WD SSD
250GB Generic HDD
https://linustechtips.com/topic/1175466-gpu-problem/
