Scratch on Hard Drive
Go to solution Solved by jaslion,
Plug it in and see. Doesn't look like any traces were hit so it's probably fine.
The drive is probably fine but you may have trouble getting Windows to work on the new PC.
Jeannie
As long as anyone is oppressed, no one will be safe and free.
One has to be proactive, not reactive, to ensure the safety of one's data so backup your data! And RAID is NOT a backup!
https://linustechtips.com/topic/1175368-scratch-on-hard-drive/#findComment-13462201
