Resevoir and Radiators aren't super important by brand, jsut made sure they're not bad, and won't break. Also I wouldn't bother as its not more than 5 dollars of difference. Also be careful with cheap res combos, as you want to always use a D5 pump.
Current Gaming build:
Specs:
CPU: AMD Ryzen 7 3800x
CPU Cooler: Corsair H100i Platinum
Motherboard: ASRock X570 Taichi
Memory: 2x8GB Corsair Vengeance RGB Pro 3000mhz 15-17-17-35
Graphics Card: Geforce RTX 2080
Graphics Card Cooler: EVGA XC Ultra Gaming
Storage: 500GB Samsung 860 EVO, 1TB Western Digital Blue
PSU: Thermaltake Smartpower 750W
Case: Corsair 460x Black
Case Cooling: A mix and match of fans ?
Peripherals:
Monitor: HP 27ea
Keyboard: Corsair K70 RGB MK.2 SE
Mouse: Corsair Glaive Black
Headphones: Corsair HS60
Microphone: Blue Snowball Black Edition
"Gaming" Laptop: Apple MacBook Pro Mid-2012 with Nvidia Geforce Now
https://linustechtips.com/topic/1175225-water-cooling/#findComment-13460055
13 minutes ago, NatersCNF said:
EDIT: any rad and pump that you might recommend?
Depends where you from and how much you willing to spend.
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1175225-water-cooling/#findComment-13460127
12 minutes ago, NatersCNF said:
I'm willing to spent around 400$cad
(285$usd)
First of all try to tag or quote ppl so we can see what you replied.
So $400 for everything yes? Res/pump combo, rads, fittings etc or just the res/pump
                                          WHIRO
https://linustechtips.com/topic/1175225-water-cooling/#findComment-13460160
1 minute ago, NatersCNF said:
yeah
That answers everything 😂
For cheap but still decent parts look for something from Barrow.
                                          WHIRO
https://linustechtips.com/topic/1175225-water-cooling/#findComment-13460169
Id say go cheap on the res but that depends of its something you have to look at a lot. I really prefer the res's that go in a fan spot.
Rads being cheap is fine if you aren't cooling much or have room for multiple.
https://linustechtips.com/topic/1175225-water-cooling/#findComment-13462805
27 minutes ago, NatersCNF said:
I've actaually thought it through and am going to use more expensive water cooling parts.
Not sure how’s the market in Canada but in UK I bought all my parts for loop brand new, never used but from second hand, mostly ebay. It takes time to collect all components this way but you can save bunch of $
I’ve spend on my loop £350, if I want to buy it from shop it would cost me roughly £800
                                          WHIRO
https://linustechtips.com/topic/1175225-water-cooling/#findComment-13463060
1 hour ago, NatersCNF said:
I feel like the main thing will be trying to get a gpu block for a cheaper card then a 1080 ti
I've been looking for block for a 2060 super that isn't a founders.
know anything about that?
Try to tag or quote people so we can see replies.
I know Bykski have few block for 2060, also EK and Phanteks have few blocks for 2080/2070 cards which are compatible with 2060 check this
https://www.overclockers.co.uk/water-cooling/water-blocks/graphics-card?sSort=2&ckTab=0&ckFilters=7016
                                          WHIRO
https://linustechtips.com/topic/1175225-water-cooling/#findComment-13463508
