PCB layouts don't have to be filled - need pictures of what you are talking about along with all pertinent information of the GPU.
Im not sure about the back USB ports but if your HDMI/DVI/VGA or whatever ports on the mobo stop outputting that is because you put a dGPU in the system, rather than the iGPU (based out of the CPU) displaying.  Move the cables to the graphics card outputs.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
The GPU is sold as a used Radeon HD8570 on ebay for 14.99 USD.
4 minutes ago, Tom_nerd said:
the back USB ports would not be affected by your graphics card, and its probably just some non filled contacts. its probably not a missing capacitor
My usb ports work when it's not in, but when it's in they dont.
Bottom right of picture is a PCB blank where a capacitor could go, but that would need you to then look at the contacts of the metal, see if something was broke off or not (and then verify through another picture of a exact same cards PCB).
What motherboard?  Though I haven't heard of it before it may be that when adding a dGPU it could be taking from some chipset stuff that communicates with USB.
MIH61R. It's a dell vostro 260 with 8GB of 1600 ddr3, and an Intel core i3-2120
Have you checked to see if BIOS is up to date?
Uhhh no but I did update it to A10 idk if it is the most up to date or not but... I also tried using a dvi cable and it didn't output video so I think it's safe to say the graphics card is dead right?
