Hi
After installing the latest bios to my b450, the 3600 i installed showed no signal but was running fine with my 1500x with new bios
I reinstalled the 1500x and still no signal and red cpu light, I have tried display port on gpu and hmdi into mobo.
The pc starts fine. All fans on, but it shows the red cpu light and no signal to monitor.
I since in a separate incident bent the pins on my 3600, but the pc still shows no signal with the original 1500x which is undamaged.
What could have caused this ?
I have ordered a b450 max and another 3600 and going to start a fresh with a new install of windows, new ssds and cpu.
If this problem persists could it be the memory or psu ?
Really confused as to how I can go from a healthy 11month old set up, to one which doesnt work.
Thanks to all. This is a great forum
https://linustechtips.com/topic/1173646-please-help/
