depending on the case, vertical mounting will have worse airflow than a normal mounting as it will be pressed against the side panel(in current trends, most likely glass) which in turn can affect temps.
It would look cool though. you can fully display the GPU especially if its RGB. though it will hide the back plate if it has any.
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1172882-vertical-mount-gpu/#findComment-13441336
5 minutes ago, DarkMedic said:
But will the vertical mount itself weaken or break after some time, or the GPU's connecting 'finger' will weaken or break after some time?
Sometimes vertical mounts have brackets that hold the GPU in place like a motherboard, unless you plan to move this thing around alot, or possibly bump it into many walls, otherwise you should be fine.
https://linustechtips.com/topic/1172882-vertical-mount-gpu/#findComment-13441346
If you get something like that
it’s going on the place where the pcie slots are, this gives you plenty of space from the case side panel which not gonna affects airflow of the gpu.
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1172882-vertical-mount-gpu/#findComment-13441579
