Ram Compatibility Help
Solved by tarfeef101,
Yeah, that should work at the rated 2666MHz speed right out of the box, no issues.
FYI if you want to see if a motherboard has verified a specific kit of memory, on the support page for the motherboard they have a "Memory QVL list", which lists every kit they have tested to work. In this case, it is here: https://www.asrock.com/mb/Intel/H310CM-HDV/index.asp#Memory
