I continue to have problems with my system that I cant find a solution to(it keeps getting worse). I will try to describe everything that is happening.
  1. When I right-click on a jpeg the blue loading circle shows up and stays until the whole screen turns white(similar to a program not responding), eventually everything will disappear(all open pages, desktop icons, and the taskbar) and reappear like it's reloading.
  2. More recently I have experienced more crashes(not blue screens) the screen turns black and I can't do anything except restart.
  3. The most recent problem is the desktop and taskbar will freeze randomly. I can still click on things, but there is no animation. Even the clock freezes.
PC Info:
OS - windows 64 bit
MOBO - MSI 990FXA Gaming
CPU - AMD Fx8350
GPU - MSI R9 380
PSU - EVGA 650BQ
More Info:
I don't have an OC
I have run scans with Norton, Malwarebytes, and Hitman
https://linustechtips.com/topic/1172675-system-freezing-and-crashing/
Reintall Windows.
It may not be the problem, but will save tons of time in trying to find a solution, what you are describing in first point is explorer.exe crashing, it could be a SSD/HDD issue, it could be RAM or anything else, but whatever it is, Windows is definitely involved and will take too long to try and fix, so reinstall.
15 minutes ago, Psykicwarrior said:
Reintall Windows.
I will try to do that
