Hi All,
I am looking to upgrade/rebuild my pc for use as an engineering student as well as casual gamer. I currently have an RTX 2060 6GB which I will transfer to the new build, but other than that I will be buying new components from the case to the CPU. Any suggestions or comments on my proposed build below would be great.
1. Budget & Location
Around £900 GBP, United Kingdom
2. Aim
I am an engineering student, and also a casual gamer. Looking for a system that can run CAD modelling software and also various 3D simulation programs; but also handle games like Battlefield V, Arma 3 at 1080p.
3. Monitors
Currently using 1x 1080p monitor, no plans to upgrade resolution at the moment.
4. Peripherals
Looking for new mouse and keyboard, currently looking at Razer Hunstman and Deathadder Elite for £160.
5. Why are you upgrading?
Current PC is using an i5-4690k @3.5Ghz, handles games relatively well but is really struggling with some of the simulation software and CAD rendering I am trying to do. Looking for a rebuild that will last for the next 3-4 years with room for upgrades if need be.
Proposed build:
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor £270
Motherboard: MSI B450 TOMAHAWK MAX £105
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory £81
GPU: RTX 2060 6GB (Already Owned)
Case: Corsair SPEC-DELTA Carbide £60 (Any case under £100 really)
PSU: Corsair 650W TX650M £85
Storage: Samsung 860 EVO 500 GB £72 for boot disk and a few games (Already own 1 x 2TB Hard drive for majority of files)
Peripherals: Razer Hunstman + Deathadder Elite £160
Total is around £840.
I haven't included a CPU fan as I have read that the stock cooler is more than adequate, I am not planning to overclock if I can avoid it.
Cheers Guys
https://linustechtips.com/topic/1172581-engineering-student-pc-rebuild/
AMD have better boosts with a better cooler. Though its up to you if you need that boost.
i think if you can find a case that has better airflow, the better. that plastic front with small mesh holes literally smells like a hot box.
other than that, that build looks good
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
