ive been asking this question for a long time and no one can help me so.
13 minutes ago, Quackwich said:
1 minute ago, Projex said:
Thanks. I'll probably buy it if its in stock soon
also this is not a very good laptop for the price, i really would recommend not getting it.
If my Response helped you, Please click the Check under my reply, to mark it as The Solution!
https://linustechtips.com/topic/1172343-laptop-finding-help/#findComment-13437067
How do you know the price? It's not in stock
https://linustechtips.com/topic/1172343-laptop-finding-help/#findComment-13437121
