Hey guys im new on the forum & i have a little question.. some one knows if the bitspower aorus 2080 xtreme waterblock fit in the aorus 2070 super? 99.9 the same pcb but im not sure can someone please help me? :C the pcb has the same number
This is the Aorus 2070 super PCB
This is the Aorus 2080 xtreme PCB
Gigabyte-Aorus-GeForce-RTX-2080-Xtreme-8G-8GB-GDDR6-GV-N2080AORUS-X-8GC-pcb_5e32eeb056b07.thumb.jpg.a547c28ac07da436434eec28d5f0e386.jpg
and this is the water block
https://linustechtips.com/topic/1172137-help-with-waterblock/
@White Wolf66 looking at both of them yes it should work, basically same pcb , same layout just different die. But like mentioned above try to contact Bitspower, if they don’t have answer for it maybe hit up Gigabyte and ask if its same.
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1172137-help-with-waterblock/#findComment-13435659
2 hours ago, the_saint said:
This is a great question, have you tried asking the waterblock company yet?
It does appear that it would work at first glance but I would wait for more responses
yess but no answer maybe tomorrow i just send the mail today thnks man
https://linustechtips.com/topic/1172137-help-with-waterblock/#findComment-13436061
 i send an email to bitspower but no answer yet ill try with gigabyte thanks!
https://linustechtips.com/topic/1172137-help-with-waterblock/#findComment-13436066
