So how do i explain this, recently ill be playing games on my computer and all of the sudden my pc will just start stuttering hard, freezing for a few seconds sometimes. This stuttering wont stop until i completely restart my computer which i have to do with the reset button on the case because it stutters so much that i cant open the windows menu . Its not the specific game im playing because it happens on any game and it totally locks up my whole computer not just the application im running at the time. Often now on start up i have to restart before even getting past the lock screen of windows. It also now has to repair the disk windows is installed on when i restart it (which did not happen when this problem first started occuring) so im wondering if the ssd is the problem. Please any help is appreciated.
Btw these are my specs:
Ryzen 7 3700x
geforce rtx 2080 super OC
corsair vengeance ddr4 3200mhz 32gb
asus prime x370-pro
sandisk ssd plus 120GB (windows is installed on this)
1tb hard drive and nvme ssd
https://linustechtips.com/topic/1171846-please-help/
Just now, NZgamer said:
Yeah that'll be it. Chewing up your RAM.
Didn't read it properly sorry
I thought this could be it at first but again I had been doing this before this started happening and i usto even do it with less ram than i have now which is why doubt that'd be it but thank you anyways.
https://linustechtips.com/topic/1171846-please-help/#findComment-13433124
Hows the temps of your system?
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1171846-please-help/#findComment-13433415
gpu usually tops like 80 max but normally with the games im playing its at like 50 and id say my cpu sits around 60-70 depending on the game ill have to check their temps next time it happens but normally i cant even open task manager bc of the stuttering so hard to say the exact temps at the time it happens.
https://linustechtips.com/topic/1171846-please-help/#findComment-13433517
Check your device manager, make sure you don't have driver less PCI devices
Also make sure you have the latest BIOS on your last gen X370
Ryzen 7 3700x
asus prime x370-pro
In what kind of case do you houses all this wonderful gear?
CPU Ryzen 5900X - Motherboard Asus ROG STRIX X570-E - RAM 16GB of G.SKILL NEON 3600 -
GPU EVGA RTX 3080 XC3 - Case Mastercase H500p mesh - PSU Seasonic Focus Gx-850 -
Corsair MP600 NVME 1 Tb, Samsung 960 PRO 500 Gb & 2 Seagate Baracuda 7200 RPM 2TB in stripe -
Display two VG27AQ 2K monitor - Cooling Corsair H150 Pro -
Keyboard G-910 W/ Romer G tactile - Mouse G 502 Hero (wired) -
Sound Logitech X-530 and Razer Tiamat headphones
Operating System Windows 10
https://linustechtips.com/topic/1171846-please-help/#findComment-13434858
i will check my drivers but i think they should all be set and i did updated my bios before getting the 3700x so that it would run on this mobo. My case is the Cougar MX330
https://linustechtips.com/topic/1171846-please-help/#findComment-13435621
Seems the case should have enough airflow.
70-85 is pretty hot. How do you cool your CPU?
I can get my 3700X at those temp after 3 cinebench runs (I got a 360 mm AIO)
https://linustechtips.com/topic/1171846-please-help/#findComment-13438973
