So, I am considering swapping my pre-built xps 8930 special edition tower into a new case, and I failed to find what size case I would need for this swap (atx, itx, etc.) I would also be looking into swapping out the power supply but I have no clue on what cables are required to buy to swap it out, sata, etc. or if they come provided.
I would also like to expand storage in it eventually.
It is running an i7 9700
RTX 2060
24gb DDR4 2666 ram
1 m.2 ssd
1 Sata hard drive
Thank you!
https://linustechtips.com/topic/1171832-help-please/
Guess you won't be having an I/O shield then.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1171832-help-please/#findComment-13433029
1 hour ago, Luckyprock said:
No I wouldn't have an IO shield, and I don't really see what it does if you could enlighten me that would be great
It’s just for aesthetics nothing else so don’t worry too much about it. If you expanding the storage and assuming you gonna use ssd or hdd you’ll need sata cable, just the one to connect to the mobo. To power it up you gonna have all cables included with psu
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1171832-help-please/#findComment-13433408
