Hello,
This is my first post and don't know how to start this...
I'm planning to buy my fist desktop pc,
i can't build one so I'm buying one ready built.
i have 3 options which are all priced not far from each other but have slightly different specs and I don't know which one is better value for my use.
And if these builds are good or bad.
I will use it for music production as a hobby not professionally also for casual gaming and photo editing and little bit of work.
I'm getting a desktop pc instead of a laptop because i had laptops and for almost 10 years never used it out of the house so I thought why compensate the performance for portability and not use it.
note:
i live in KSA and the prices may seem expensive.
(spec lists attached)
1st option:
Price is equivalent to USD 1,370
Motherboard: Gigabyte B365M H
Processor: i5 9400F 2.9GHz
RAM: 16gb DDR4 2666MHz
GPU: Gigabyte RTX 2070 Super 8gb GDDR6
Power Supply: Thermaltake 650w
2nd option:
Price is equivalent to USD 1,410
Motherboard: MSI Z390-A Pro
Processor: i5 9600K 3.7GHz
RAM: 16gb DDR4 3000MHz
GPU: Gigabyte RTX 2060 Super 8gb GDDR6
3rd option:
Price is equivalent to USD 1,570
Thank you everyone in advance
https://linustechtips.com/topic/1170754-first-ever-pc-need-help/
46 minutes ago, boggy77 said:
are there any ryzen alternative? they are better for music production and editing and usually cheaper for the performance they offer.
I couldn't find any ryzen,
as for music production I'm not a heavy user
so I don't think i need higher specs
my current laptop uses 3rd gen i7 and it is from 2013.
i think anything above that is good for me , but I'm concerned about the gaming performance.
i would definitely try to get the i7. the i5 is already obsolete for gaming
Just now, Malfraij said:
But is it worth the price difference for casual gaming?
the way I see it:
i would pair the i5 with the 2060 super
i would pair the i7 with the 2070 super.
it all depends on the kind of games you're playing, what monitor you have, and what performance you're expecting.
Just now, boggy77 said:
the way I see it:
Games like COD Warzone, apex legends, pubg, and need for speed( pretty much all games i play)
monitor is an Acer Gaming monitor 27" 1920 x 1080 1ms 144Hz
as for expected performance I don't know what to expect as I've never experienced pc gaming since red alert.
you'll get good performance in those at 1080p with either build.
https://www.gpucheck.com/en-usd/compare/nvidia-geforce-rtx-2060-super-vs-nvidia-geforce-rtx-2070-super/intel-core-i5-9400f-2-90ghz-vs-intel-core-i5-9600k-3-70ghz/high/high/-vs-
I would go with the 2nd one for 1080p gaming. The i5 9600k is slightly better than the i5 9400F. Faster ram. A 2060 super is enough to get 1080p 144fps.
Quote me or mention me at @Shrekpad so I get notified
pc specs:
CPU:
Intel i7 8700K MOBO: ROG Strix Z390-E Gaming RAM: 16GB (2x8) DDR4 G Skill TridentZ 3000 MHz GPU: Gigabyte GeForce RTX 2080 SUPER GAMING OC CASE: Phanteks Enthoo Evolv STORAGE: Sabrent Rocket Q 1TB M.2 NVME SSD,
T-Force Delta RGB 250GB SSD, 4TB Seagate Barracuda HDD PSU: 750 Watt EVGA SuperNova G3 MONITERDell S2716DGR 1440p 144hz G-Sync, BenQ PD2700U 4K 60hz CPU COOLER: Corsair H115i RGB Platinum OS: Windows 10
i agree. with the second build, for $40, you get better cpu and faster ram.
Edit: Nevermind, you also get a worse gpu. not sure what to pick here.
i choose to up my budget a little bit to get i7 due to alot of negative feedback.
now have 3 new options and are confusing as hell,
could you help?
option 1
price USD 1,750
Motherboard INTEL ASROCK Z390 GAMING 4
GPU GALAX RTX2070 Super 8GB EX ONE CLICK OC
CPU Intel® Core™ i7-9700KF
RAM Team Group Vulcan z 16GB 3200MHz RED
PSU PS Antec 700W
HDD N/A
SSD SSD GEIL Z-R3 1TB
Cooling KWG WATER COOLING RGB 240ML
option 2
price USD 1,820
Motherboard MSI Z390 - A Pro
GPU GIGABYTE GEFORCE RTX 2070 SUPER OC  RGB FUSION 2.0 - 8GB GDDR6
RAM CORSAIR VENGEANCE LPX  DDR4 - 16GB 3000MHz
PSU RAIDMAX VORTEX 700W 80+ BRONZE
HDD TOSHIBA PC P300 3.5" 2TB SATA 7,200 rpm 64MB
SSD SSD M.2 256GB
Cooling CORSAIR H45 120mm LIQUID COOLER
option 3
price USD 1,660
Motherboard ASUS TUF Z390 GAMING WIFI
GPU ASUS ROG STRIX NVIDIA 2070 SUPER ADVANCED EDITION 8GB OC
RAM CORSAIR VENGANCE PRO RGB 3000MHz 16GB 8X2
PSU SEASONIC 650 WATT 80+(GOLD) ASUS TUF EDITION
HDD 1TB 7200RPM
SSD TEAMGROUP® 240GB SATA 3 ULTRA FAST 530MB/SEC
Cooling DEEPCOOL GAMMAXX GTE RGB
