Gaming pc help.
Go to solution Solved by Fasauceome,
18 minutes ago, AGF said:
saving money isnt essential more so future proof. I've heard a lot of good things about AMD it's just I'm not familiar with the brand is the ryzen 7 the equivalent of the i7
A Ryzen 7 is the competitor to the i7, but it has 8 cores and 16 threads so it's closer to the i9. Also, with AMD you get better Upgrade options, with the new 4000 series coming this year as well as up to 16 cores with the 3950X.
The CPU is overpowered for this PC, since it is primarily for gaming. That's money that could have gone to the graphics card.
Are you only considering prebuilt configs? Also, we can't tell you if a PC is good or not if you don't tell us the price.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1170489-gaming-pc-help/#findComment-13420640
Just now, Fasauceome said:
The CPU is overpowered for this PC, if it is primarily for gaming. That's money that could have gone to the graphics card.
Are you only considering prebuilt ocnfigs?
yes prebuilt. i could always just swap my graphics card in the future, right?
https://linustechtips.com/topic/1170489-gaming-pc-help/#findComment-13420652
If you get a decent power supply, yes. The Vengeance listed in the build above is good.
Are there any core i7 models to consider?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1170489-gaming-pc-help/#findComment-13420656
i kinda wanted to get the i9 just so i wouldnt have to replace it in a few years. isnt it easier to replace a gpu then a cpu?
https://linustechtips.com/topic/1170489-gaming-pc-help/#findComment-13420668
There's no guarantee that an i9 will outlast an i7. It is easier to upgrade a graphics card, though.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1170489-gaming-pc-help/#findComment-13420676
oh i was under the the impression the i9 is just dominant compared to the i7. looks like the pr team did a good job on me
it has hyperthreading, so it is better, but for modern gaming they'll deliver the same experience, and by the time one is obsolete, the other likely will be as well.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1170489-gaming-pc-help/#findComment-13420699
 okay thank you, so something like the i7 9700k would do a good job.
think i'll go back and look at some i7
https://linustechtips.com/topic/1170489-gaming-pc-help/#findComment-13420717
definitely. A ryzen 5 3600 or Ryzen 7 3700X are also great ways to save money.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1170489-gaming-pc-help/#findComment-13420719
https://linustechtips.com/topic/1170489-gaming-pc-help/#findComment-13420734
Primary PC:
PSU tier list
https://linustechtips.com/topic/1170489-gaming-pc-help/#findComment-13420802
thank you ive had a good look and im going for a AMD thank you again
https://linustechtips.com/topic/1170489-gaming-pc-help/#findComment-13420924
