It's dead. Get anything you might need off of it if you still can, and to the trash it goes.
F@H
GPD Win 2
https://linustechtips.com/topic/1170338-hdd-not-working-help/#findComment-13419495
8 minutes ago, Harry777 said:
I got a new Toshiba MQ01ABD100 1TB HDD, I accidently dropped it the floor. After that it can only store 20tb of data before you get an error, after that error your file explorer stop responding. I tried formatting the HDD. Can someone please help me.
Dang so it went from a 1TB HDD to a 20TB HDD? Or did you mean 20GB?
Anyway run windows chkdsk command and see what it says, or crystaldisk mark, but its most likely pretty dead.
also if its new you could probably file an RMA and say is was defective when you got it.
Quote me or @TwilightRavens if you want me to see your reply. I may go inactive for a long time from time to time because I forget how to socialize, but I will be back... eventually.
Main Gaming PC
AMD Ryzen 9 5950X || AsRock X570 Taichi || G.Skill TridentZ Neo DDR4 3600MHz 2 x 16GB C16 1.35v || AMD Wraith Prism || Phanteks Enthoo Pro E-ATX || Gigabyte RTX 3080 Ti Gaming OC || Samsung 970 Evo 250GB NVME SSD & Samsung 980 Pro 2TB NVME & Crucial 960GB SATA III SSD || EVGA Supernova 750W Platinum PQ || Windows 10 Pro 22H2 x64 || Gigabyte M27Q 27" 170Hz 1440P & Acer 21.5” 1080p 75hz IPS || Logitech G213 Prodigy || Logitech G502 Hero
Laptop
AMD Ryzen 5 4600H with RadeonGraphics || ASUS TUF A15 ||  DDR4 3200MHz 2 x 8GB C22 1.2v || ASUS GeForce GTX 1650 4G GDDR6 || 512GB NVME M.2 SSD  ||  Ubuntu 22.04.1 (Jammy Jellyfish)
https://linustechtips.com/topic/1170338-hdd-not-working-help/#findComment-13419499
