Need Help
Go to solution Solved by TheBreaker,
It doesnt, but, the 260X comes with a dual molex to six pin, so you'll be fine.
okay, so i bought this power supply   http://ca.pcpartpicker.com/part/antec-power-supply-bp350   for a new build, and im going to get this card   http://www.directcanada.com/products/?sku=16950BD1216&vpn=R7260X-DC2OC-2GD5&manufacture=Others.   After looking at the PSU, i dont think it has enough pci-e power cables. Can someone confirm this. I need to know if i have to send it back.
Main Rig
CPU-
AMD FX 8350 | CPU Cooler- CM hyper 212 Evo | GPU- Radeon HD 7970 | RAM- G.SKill Ripjawz X 2x4 | Storage- 1TB WD Black | 128gb Plextor Ms5 | Case- BitFenix Shinobi   | Motherboard- Gigabyte AM3+ UD3 | PSU- Rosewill hive 750 watt
 Media PC
CPU- A10-5800k | GPU- Onboard | RAM- Ripjaws X 4Gb | Storage- Seagate 1TB | Case- Bitfenix Prodigy M | Motherboard- MSI A75M-E35 | PSU- Antec 350W Basiq
https://linustechtips.com/topic/117019-need-help/
@HybridB Aaaa... are you seriously trying to run an OC'ed  fx 8350 and a 7970 on a crappy 350w psu?
no, as i said, new build. Just need to know if it has the right cables to power that card
Main Rig
CPU-
 Media PC
https://linustechtips.com/topic/117019-need-help/#findComment-1562068
thanks for the quick reply
Main Rig
CPU-
 Media PC
https://linustechtips.com/topic/117019-need-help/#findComment-1562072
