I am running
Ryzen 5 3600x
16GB LPX 3200mhz (single channel)
MSI TomaHawk B450 motherboard,
120GB M.2 SSD WD
MSI ARMOUR RX 570
The problem is I am getting crash in all games with all the new driver from AMD form driver version  adrenalin-2020-edition-20.2.1 - 20.3.1
Tried fresh windows installation twice but to help , lastly I am using AMD driver crimsion 17.3 in this some game working and some do not
KINDLY HELP ME OUT PLEASE
https://linustechtips.com/topic/1169919-need-help-regarding-pc-config-gpu-and-cpu/
1 hour ago, 5x5 said:
Update your BIOS, OS, your firmware and other drivers. DDU the video drivers and install the latest WHQL signed ones.
Tried still same issue
also used another GPU ncidia gt 730 it is working fine and my GPU RX 570 used in another pc also working fine , I am just messed up man
any other solution ?
After you run DDU to clear everything, when you go to install the drivers again, do you use the 'Factory Reset' option?
You need to click on 'Additional Options' then check the box.
That extra step helped me quite a bit with my RX470 issues.
Did all ma still no result , all crimson drivers are working but all adrenaline driver are not working , I can not play the latest games man
