I have never built a gaming pc and I'm trying to switch to the master race. I plan to mostly play Rainbow Six Siege and League of Legends. I'd like to get above 100 fps. I know Ryzen is typically better than intel but my dad hates amd so I can't switch. Here is my part list: https://pcpartpicker.com/list/sjxjb8    Don't care about rgb. Plz advice.
https://linustechtips.com/topic/1169597-need-advice/
Are you buying from the United States?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1169597-need-advice/#findComment-13412901
9 minutes ago, YOURFACSZ said:
yes
Saved you some money with non-RGB ram, non-overclocking motherboard, and locked i7.
Cheaper SSD as well, and put the extra money into the graphics card. A 2070 super is slightly overkill for 1080p 144Hz, but doesn't hurt to have the extra oomph.
Of course, if you're just getting this from a local shop and the price is rather low for the parts you selected, it's a fine build.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1169597-need-advice/#findComment-13412960
Thank you so much
https://linustechtips.com/topic/1169597-need-advice/#findComment-13412986
Is your dad buying the PC? Because if not, why is he giving you orders on what you can and can't buy for your rig? Even if he is buying it, he should cut the fan boy ignorance do some research and realize that AMD has great chips now.
Good luck!
Jesus is the way, the truth, and the life.
Please Quote me when replying.
CPU
 - Ryzen 7 5800X3D | RAM - 32GB DDR4 4000Mhz | MB - MSI B550 A-PRO | Boot - 2TB NVME 980 Evo Plus | GPU - EVGA FTW3 RTX 3090 24GB
https://linustechtips.com/topic/1169597-need-advice/#findComment-13413169
Good luck!
He is buying it. He should cut the fan boy ignorance but he doesn't plan on it. Thx
https://linustechtips.com/topic/1169597-need-advice/#findComment-13413181
Alright well good luck to you sir/maam. I'm not gonna post a build since so many others already did. Have fun on your first build, its exciting!
CPU
https://linustechtips.com/topic/1169597-need-advice/#findComment-13413189
