I was just wondering if i need any tools to fill this https://www.newegg.com/corsair-liquid-cooling-system/p/N82E16835181141?Item=N82E16835181141 also, that my motherboard is compatible with my case: Motherboard: https://www.newegg.com/msi-z390-a-pro/p/N82E16813144219?Item=9SIA85V8TR9428 Case: https://www.newegg.com/black-corsair-crystal-series-570x-rgb-atx-mid-tower/p/N82E16811139087?Item=N82E16811139087 This is my first time actualy building a pc so i need all the help i can get.
https://linustechtips.com/topic/1169291-first-time-doing-liquid-cooling/
3 minutes ago, ErA.l said:
That is a "closed loop cooler", it comes pre-filled. No need to do anything to it, it should be ready to go out the box.
The motherboard is ATX, and the case is ATX compatible, so everything should fit fine.
Thank you, that was all the info i needed
