Hey i have a problem my pc keeps crashing and i don't know why i checked everything and i didn't find anything so im asking you for your help. When im working or gaming my pc just stops working the screen freezes i can move my mouse and my keyboard still works but the screen is just frozen and then couple seconds later the keyboard and mouse stop working and the screen turns off and couple of minutes later the pc starts working again sometimes he just crashes and turns off so i dont know what to do:/
pc specs:
cpu: ryzen 71700 eight core
gpu: geforce 1060 6gb
ram: corsair vengeance lpx 8gb
motherboard: asrock a320m-dgs
if you need more information about my pc then just comment that
if you have any solutions please help me i would really appreciate it thank you have a great day!
https://linustechtips.com/topic/1169094-i-need-your-help/
cek the cpu temp, if idle over 50c and load over 85c, you have a cooling problem.
for the memory test it with memtest86
https://linustechtips.com/topic/1169094-i-need-your-help/#findComment-13408255
i have checked the temps of the cpu it seems normal i also tested the memory but everything seems alright but i have noticed something when my pc crashes the graphic cards fan stops spinning so i think it might be a graphics cards problem any suggestions?
https://linustechtips.com/topic/1169094-i-need-your-help/#findComment-13411411
1. Make sure drivers are up-to-date if you can before it crashes.
2. Reseat the card.
3. Reinstall drivers.
I'm assuming this isn't a new build so this problem is new?
Gaming/Editing PC
Motherboard: Asus ROG Strix Z370-E CPU: Intel Core i7-8700K Cooler: EVGA CLC 240 GPU: Asus Dual Edition RTX 2070 Super OC RAM: Corsair Vengeance 16GB @ 3000 MHz PSU: Corsair HX650 Case: Fractal Design Meshify-C White
https://linustechtips.com/topic/1169094-i-need-your-help/#findComment-13411924
2. Reseat the card.
Yea this pc is 2-3 years old and yes this is a new problem..
Thanks i will try that.
https://linustechtips.com/topic/1169094-i-need-your-help/#findComment-13412428
2. Reseat the card.
so i found out ir might be the gpu  problem because when i turned on the pc i heard some ticking sound i checked the gpu fan and it wasnt spinning
https://linustechtips.com/topic/1169094-i-need-your-help/#findComment-13430540
Well the 2060 Super is on sale for $360 right now if you can afford to replace it.
Gaming/Editing PC
https://linustechtips.com/topic/1169094-i-need-your-help/#findComment-13438920
